Results 1 to 10 of 10
Thread: Engine Question
    Sep 2000
    North Vernon, In. USA
    Engine Question
    This might be a stupid question, but can someone tell me what the difference is between a Ford and Chevy Cup engine. Are they required to use the same parts?
    Sep 2000
    Does anyboby know? Help!
    Stig's Canadian Cousin porscheman's Avatar
    Dec 2006
    Oakville, ON Canada
    Quote Originally Posted by Bill Wicker
    No. Chevy uses NASCAR approved Chevy parts. Ford uses NASCAR approved Ford parts.
    Porscheman
    price checker
    Jun 2001
    Fort Worth Texas US
    The engine designs are different as well. Many of the parts used may come from the same supplier of aftermarket parts, but probably most of the parts are not interchangeble.
    Some people will do nearly anything in order to be able to not do anything.
    Sep 2000
    Thanks Guys
    Runnin down a dream cbreez99's Avatar
    Oct 2006
    anclote key, fl
    They are like the COT...they look the same, but have a few slight differences...
    the name on the rocker covers!
    Ignorant men marvel at extraordinary things. Intelligent men admire simple things.
    Mar 2004
    ABQ
    Quote Originally Posted by cbreez99
    Not at all.
    It's all very propriatary and closely guarded design information.
    Obviously when building to a "formula" things come out similar, but there's NO cross pollenation.
    Oct 2006
    anclote key, fl
    I know they are of "different" manufacture, but I am sure if you looked at the heads, cranks, pistons and intakes side by side, you would see very little difference. I have done so.Remember these are extremely limited, regulated, and almost spec engines.
    price checker
    Jun 2001
    Fort Worth Texas US
    Actually the rocker covers, heads and intakes are pretty distinctive. To an engine builder the cranks might be too. Pistons, rods, bearings, camshafts, valves and valve springs would probably all look the same to most people though.
    Before the Chevy SB1 the heads were very distinctive as the Chevy engine had the two center exhaust ports siamesed (sp). The original small block Chevy was designed in the mid 50s, while the Ford and Mopar came along later. The Toyota being a from scratch racing only engine was able to "borrow/steal" the best from the existing designs.
    The new Dodge engine is reportedly 25 lbs lighter than last year's model. With that kind of variation in one manufacturers engines, you can imagine the differences between manufacturers.
    Officer Mitchell, I thought you said you didn't want to have to come back here this evening.
