Results 1 to 5 of 5
Thread: 45 lbs
  1. #1
    American Patriot
    Apr 2001
    Sylvania, OH USA
    45 lbs
    Thats a big weight advantage for Lotus...........can Chevy and Honda shed thast much???
    ...and if you want a little peace, sometimes you gotta fight. You gotta walk throught the darkness before you stand in the light. Sammy Hagar.
  2. #2
    A friend of Hal. midtown's Avatar
    Sep 2000
    West Allis (via Indy)
    Maybe they won't want to if the block is as stiff as a wet noodle. I guess we'll see when it hits the track.
    It's a Hoosier thing, you wouldn't understand...
  3. #3
    Registered User Jakester's Avatar
    Dallas, TX
    Lotus won't have a weight advantage, at least not that much. Rules specify a minimum engine weight. If Lotus is below that weight, they will have to ballast the engine up to the minimum weight. It could translate to a weight distribution advantage as the ballast could be placed to lower engine center of gravity and thus chassis cg.
    new sig pending
  4. #4
    Registered User milliesdad's Avatar
    Mar 2010
    a state of Vicodin-induced confusion
    The car itself has a min. weight. If the separate pieces do not have a min, then the engineers are free to add the weight where it would be the most helpful.
    That is, if the car components do not have a min weight requirement.
    "If there are no dogs in Heaven, when I die I want to go where they go" Mark Twain
  5. #5
    Sep 2000
    Pretty sure that IndyCar specified a minimum weight for the engines, 212lbs maybe.
