Results 1 to 5 of 5
Thread: Dallara Suspension Options
  1. #1
    Registered User JMFVET's Avatar
    Oct 2010
    Silicon Valley, CA but New Mexican by birth.
    http://www.racer.com/dallara-offers-...rticle/219810/
    I asked this question in another thread but it was quickly buried, so I am hoping it will get some attention here in the tech and mech area.
    Would there be any advantage to running different suspension setups on the inside and outside for the oval races? E.g. longer wheelbase on outside.
    According to the linked article, Teams will have choice how they set up their cars as the original or modified suspension bits
    can be utilized in any combination front to rear at all the events.
    I am excited about this because it should make the cars better and faster but most importantly it adds a set of variables to car setup so things will be less spec.
    Congratulations to RHR, & all the winning drivers & teams in the fantastic 2012 season. Looking forward to 2013!
    We are all together now. Goal 22-24 races per year split 50:50 oval:RC/SC
  2. #2
    Addicted to Boost ZUL8TR's Avatar
    Back Home Again...
    From the article:
    "As requested by IndyCar, Dallara will design an alternative set of suspensions to move back two inches the front wheels and one inch the rear wheels,” said Andrea Toso, head of research and development for Dallara's IndyCar design team. “Both front and both rear suspensions will be available for the teams from the catalog and can be utilized in any combination front to rear at all the events. Teams will take delivery of their cars with the current set of suspensions and, should they decide to start the season with the alternative set, they can get free of charge replacement based on the return of the current set."
    If I'm reading your question correctly, I assume you are saying use original suspension on one side, then the use the optional on the other side. That could create a different wheel base measurement from side to side.
    I'm no expert, but I would think that using mixing front versions together and/or back versions together to create some sort of stagger would lend for one really squirrelly handling car when you have to drive it down a straight.
    You have the right to remain silent. Anything you say can and will be misquoted and used against you.
  3. #3
    Indy is #1 wbr's Avatar
    Jan 2008
    Indy
    I doubt it would work at Indy but might be beneficial on smaller circular type tracks.
  4. #4
    Oct 2010
    Thanks guys
  5. #5
    American Patriot
    Apr 2001
    Sylvania, OH USA
    Dick Simon did this back in 98 or 99 at oval tracks with some success...I think Hearn won Las Vegas in this type of configuration
    ...and if you want a little peace, sometimes you gotta fight. You gotta walk throught the darkness before you stand in the light. Sammy Hagar.
