Results 1 to 14 of 14
Thread: Indycar Dallara DW12 Specifications
    From Marshall Pruett. . Everthing you need to know about the new car technical specs.
    http://auto-racing.speedtv.com/artic...pecifications/
    Insider ramberg's Avatar
    Montana, Wisconsin
    Can someone tell me what the pushrod does in the suspensions? Ive never known what they actually do...
    Sulli from f(x) Hitokiri's Avatar
    Chicago
    Quote Originally Posted by ramberg View Post
    I'm not the most elegant person at explaining things but I'll try. Imagine you're driving a car and you turn you probably want the car to turn as smooth as possible and that means have both your steering tires turning at the same angles. Sometimes on our cars the turn angle between the two tires are not the same and that take more time to turn and the efficiency of the turn itself is not maximized. The pushrods allows you to adjust the angle of which the suspension is turning so that both tires are turning at the same angle or whatever angle you want them to be. The pushrods also balance the suspension of the car by "pushing" or "see sawing" each other back in forth keeping the balance of the car optimal. I'm not sure if that made any sense but I tried. Look...someone is going to come in and call me wrong anyways. :P
    "The only good horsepower is usable horsepower.."
    Insider sabin_24's Avatar
    Feb 2002
    Chesterton, Indiana
    The pushrod connects the upright to the damper (spring) via a rocker. When the wheel goes over a bump, it pushes on the pushrod, which in turn pushes the rocker, which pushes on the damper, absorbing the shock of the bump. The last chassis used a pullrod suspension, which acted in the exact opposite manner of a pushrod. When the wheel goes over a bump, it pulls the pullrod up, which pulls on the rocker, which pushes on the damper.
    Insider BADGER's Avatar
    May 2001
    IL
    Stick with Sabin 24's explanation, the other one seem like he confused the purpose of a pushrods with Ackerman steering.
    Does this mean we might see a DW12 on rFactor soon?
    Registered User JMFVET's Avatar
    Oct 2010
    Silicon Valley, CA but New Mexican by birth.
    Great explanation of pushrods and pull rods here, http://www.f1technical.net/articles/39
    Congratulations to RHR, & all the winning drivers & teams in the fantastic 2012 season. Looking forward to 2013!
    We are all together now. Goal 22-24 races per year split 50:50 oval:RC/SC
    There is no substitute. Spike's Avatar
    Aug 2002
    Driving the point home
    Quote Originally Posted by Hitokiri View Post
    Imagine you're driving a car and you turn you probably want the car to turn as smooth as possible and that means have both your steering tires turning at the same angles. Sometimes on our cars the turn angle between the two tires are not the same and that take more time to turn and the efficiency of the turn itself is not maximized. The pushrods allows you to...
    Wow. And, no. You may be thinking of "tie rods." Pushrods, in the context of this thread, have nothing to do with steering.
    Creative, I suppose, but completely wrong.
    The main reason pushrod suspension came into use is that it allows the coilover spring/shock units to be moved out of the airstream to reduce aerodynamic drag and provide cleaner, less turbulent airflow to side pod air intakes and the undertray. Other benefits include reduction of unsprung weight and improved handling by moving the weight of the coilover units towards the centerline of the car. Further, by selecting different pickup points on the rocker arm (which alters the ratio of suspension travel to spring/shock travel), you can quickly make changes in the damping and spring rates.
    "The IRL's future should be good, but it can't be the grass-roots series Tony George envisioned. That was a wet dream." - Bobby Unser
    Montana, Wisconsin
    Thanks a million guys...
    doitagain's adopted son aaron5572's Avatar
    Apr 2010
    SEC Country (Kansas City/Columbia, Missouri)
    Quote Originally Posted by andy5446 View Post
    yeah they're already designing it, I saw it on another site, looked real good
    The Original Fan of Kimi "The Iceman" Raikkonen 2007 World Driving Champion: 20 Wins---72 Podiums---16 Pole Positions---38 Fastest Laps ---1 Gorilla Suit 2013 Australian Grand Prix CHAMPION
    How did the weight end up exactly back to where it was on the IR07? Where did it end up heavy? That's substantially higher than what it was supposed to weigh.
    Feb 2002
    Chesterton, Indiana
    Quote Originally Posted by Gomer Simpson View Post
    It was a combination of a lot of things. A few components that I remember hearing about that were heavier than anticipated were the side intrusion panels, rear wheel guards, and the gear box. I'm sure there are other components which added to the overall weight, too. I guess one positive is that with the fuel cell mistake, they'll be carrying half a gallon less fuel, which saves them about 3 lbs with a full load.
    Mar 2006
    Speedway, IN
    Well, you got that part right!
    Oct 2010
    Not that I trust ESPN on ABC for reliability and accuracy, but the just showed a comparison Btwn the cars and had DW12 listed in at 1560#.
