I was thumbing through the Indy 500 records and noticed that in the early 80s, a "Pontiac" engine showed up. Now I know the Buicks were stock block turbos and the Chevys were stock block atmo cars, but what is this Pontiac engine?
Megatron, kind editor of one of the webs top F1 sites:
http://www.formula-1.co.il/newf1/emain.asp
On my first trip to the speedway in 1987 I remember seeing Sammy Swindell running a red car with a stock block Pontiac engine. I don't think they ever got it up to speed to attempt a qualifying run.
It seems they were stuck around the 204 to 205 range.
"Don't Drive Faster Then Your Guardian Angel Can Fly!"
Dan Gurney used a stock block Pontiac V-8 for his 1984 Eagle. The 1987 effort was by John Butera in conjunction with the Machinist Union team.
It was just another attempt at making a stock block pushrod V-8 competitive. There was nothing exotic or interesting about it.
The Ayn Rand of Indycar
No one had to badge the Offy.
The Pontiacs were a small-block Chevy with Brodix heads, that were listed in the Pontiac hi-perf catalog and given a GM part number. There were two types. One was a 23-degree head with revised valve spacing. That one used special rockers and was the Winston Cup head for a number of years. There are still a lot of 'em on Late Models around the country - I had a 406 with a set a few years ago. It would thump.
The other was basically the Brodix -12 head, with 15-degree valve angle. I think this was the one run on the Indy cars, as well as the GTP cars. The -12 is still the most popular head for sprint car engines. Hope this helps.
"It was actually fun, because you're back fully driving again in these trucks. Ninety percent of the tracks we go to in the IRL, you're flat-out. I was having to lift off the corners some here." - Buddy Rice
